ColorKey doesn't cut through terrains
HelenAAHelenAA Traveler
I'm making a map and had a large block of terrain fill. I wanted to cut holes to see the landmass underneath, but it didn't work.
I had ColorKey at the top of the list of effects for that sheet - so how come it sank to the Landmass?
PS it sank to the Common Sheet!!!!!!!
    Are your pink polygons on the same sheet as the terrain you want to cut through? For it to work, there are basically 3 conditions
    • The Color Key effect must be on the sheet you want to cut a hole in, and must be the top effect in the list for that sheet
    • The colored "cutting polys" must also be on that very same sheet, on the top of things you wish to cut
    • The color specified for the color key effect must match the color of your cutting polys exactly
    • (Effects must be on)
    It is easier to see what you might have done wrong if you post your .fcw file.
  • HelenAAHelenAA Traveler
    I'm sorry but that file has been overwritten but the top two were right. I didn't realise I had to match the cutting polys - I thought the magenta was the only colour for ColorKeys; every video I've seen has been the magenta. I hadn't realised that effects had to be on either.
    The Color Key effect can work with any color you want. Magenta (Color #6 in the CC3+ palette) is used by default since very few maps would contain this color naturally, but it can be changed to another color if you need to.
    roflo1
