How can I change the text on scalebar?
Hi,
Am trying to change the text on the scalebar to be consistent with the font of the map, but it only appears to change the endpoint of the scale, i.e. the number that is entered when actually placing the bar. This is using SS4 - Dungeons of Schley.
Firstly, how can I change it so that all the text is the same as the map, i.e. I want the "0" and the "Scale in X" to be in the same font.
Secondly, how can I change the word meters to metres.
Picture below shows the default at top, what happens when I try to change the font as second, and what I would like to change the wording for, which could be useful if you use a totally different unit of measurement in your own fantasy worlds.
Thanks a lot.
