Getting ready for 13th Age Revised
I am really excited about 13tgh Age revised coming out. So I have made a start using 13th Age non-revised, and will copy it all over to the newer style come Jan 2.
Here is the FT world I created, and exported as coastline and rivers only. I didn't do any extra work on the FT map.
Here it as the FCW, with islands added from the island chain annual (I added quite a few of my own island symbols to this great little issue). I tilted the southern continent, and moved an archipelago.
The climatic zones are set at 75 deg N and S for polar circles, and 20 deg N and S for tropical zones. The green is the 40 deg N and S. I welcome comment.
Tectonics, and ocean depths all subject to variation. I will put in tectonic plates, and work out mountain ranges and volcanic activity from there.
The equatorial distance is 40,000 km
Looks great !
When the new version comes out, will you just go through and adjust each fill to the new fill? Or is there a quicker way to do a conversion I don't know about?
I will copy the whole map into a blank map of the new style. I think that will do the job. Then change the fills to the new style if necessary.
Did you get it to work? When I just copied and pasted the map, it copied the original bit fills. But maybe I did things differently than how you were going to copy it.
Here is the map copied into the new style - I just had to change the few bitmaps to the new ones - which was easy.
This is the continent I am working on at present. Had to change the effect settings a bit - the world has a 40000 km diameter.
