ss6 bug?
Hello, Sue, Ralf, and Remy
I've come across a problem with ss6. when exporting, cc3, does not include the fields I've drawn. I'll post two images. One is a screendump from cc3+ the other the exported map. I have no idea if it's a ss6 related issue since it is in beta still. It's the first time ever that a part of a map has been left out like this.
Let me know if you have specific things you want to try.
Do the fields show if you turn the sheet effects off?
Yes, they are stil there.
It looks like a transparency acne problem in that case - where the two fills both have black in them. I might be wrong, though, so I will draw Dev attention to this thread.
Thanks for raising the problem, Tommy.
Yeah, thanks the Edge Fade effect on the fields sheet (and on Terrain), doesn't really work with the back and white. Try disabling (unchecking) the box on the sheet & effects dialog.
Yeah, that did it. I can export the map with fields, if the edge fade is off.
