Deleting / Erasing along a line?
Hi, is there a way to erase symbols and other things along a line similar to what you would do in say ms paint where you erase with the mouse?
For example in the below, I initially was not going to put roads between the cities/ towns, but decided I needed them. Rather than redraw the filled in section, is there a way I could delete the forests and underlying terrain but leave the rest of the trees and terrain alone? Not keen to have to try and delete inidividual symbols. If not I may just redo them (won't take long but using this as a learning excercise as well. :)). End goal is to make it look more like the roads to the left or tp right. Mountains will stay the same.
Thanks
