Move/Scale/Rotate frames are gone
Hello,
Usually when I use the Move, Rotate, or Scale function, the program shows me a frame outline of the entity I'm manipulating to give me a clue about what the change will look like. However, suddenly it's only showing me a directional line from my initial point. If I'm using rotate, the position indicator on the status bar turns red and starts to show me the angle I've currently selected with my mouse. While that would be good and helpful in some circumstances, at the moment I need the visual feedback of the entity outline instead.
I must have accidentally found a shortcut key to activate this behavior... Can anybody tell me how to make it behave in the old/default way?
Thanks! - Greg
