Question: How to load more fill styles
How can I make additional bitmap fill styles available to me?
In my current map, I originally selected the "SS5 Cities of Shley" map style. While editing this map, I can see that nearly all of the bitmap fill styles available to me come from "SS5". If I create a new map and select a different style, then the available fill styles will be different. Is there a way to bring other bitmap fill styles into this map?
Check this FAQ topic:
That worked. I may have never discovered it on my own, but it makes sense in retrospect. I'll go read the FAQ now.
CC3+ has a ton of features, and many ways to accomplish different goals.
There's also a ton of resources to get yourself familiarized with CC3+: one of them is the FAQs like you said, the help files within CC3+, there are a few PDF manuals that should be on your PC when you installed CC3+, there are a few technical posts in the blog, there's the official youtube channel, and of course there's this forum.
And with so much information, some times the best place to start is to ask for pointers right here in the forum. :)
You'll find there's a lot of helpful people here, willing to help you out.
