What was the bug in HCC3's installer?
I got an email saying that the setup installer in HCC3 has been fixed.
If I didn't notice any error while installing, is it safe to assume I downloaded the fixed version?
In other words, I would have noticed if I'd used the bugged installer, right?
You would have had missing parts. If you have everything you bought then you downloaded the updated installer.
Not sure if I follow. Should I check if all the listed styles are available?
Some of the installers were missing, that's all.
If you have all of these, then you're fine.
If you don't, then you will need to redownload.
It was a corruption in the zip file. You wouldn't have been able to install the broken version in the first place. So if the setup worked, you've got the fixed version.
