Very nice work for a first map! My only suggestion would be to try playing around with effects on the Text sheet. Maybe add a Glow (outer) in a darker color (like a dark brown) to the text to make it stand out more?
Very nice first map. CC3 makes it so darn easy to produce great maps. Perhaps you could make the edges of your forests more irregular & have a few trees standing alone a little way from the edge of the forest. Sometimes it is nice to add a separate sheet with a medium brown irregular shape & give it a blur & a transparent effect around the cities as if it was a tilled area. Good luck as you create more maps.
Posted By: SvenSometimes it is nice to add a separate sheet with a medium brown irregular shape & give it a blur & a transparent effect around the cities as if it was a tilled area
In the same way I would add a blur effect to the brown areas under the mountains and the green ones under the trees. Perhaps you already did it in that case I would increase the blur radius but keep the strength to 0.
