Ferraris Troubles
Hello all,
I've used the Ferraris Annual several times and produced some decent maps.
Recently I've worked to try and get into more of these types of maps and am running into a problem. When I work on the layout of the map and attempt to load the "Vegetation" I get no response from the program and then it just disappears on me without saving any work.
It did this on my desktop only it was with the "natural features" portion. Looking for help here and hoping I don't need to reinstall everything.
Eric
Hi Eric :)
When you say 'load', do you mean manually by opening the catalogue from the folder button at the top of the symbols panel, or automatically using the vegetation button? Also, which template are you using - imperial or metric?
I haven't much time today, so I'm hoping this information will help others solve the problem if I'm not around at the right time.
Would you mind very much uploading the drawing here so that we can see if we can crash it too?
I made a with using CC3+ version 3.97. I haven't moved to 3.98 yet. I open the load options using the yellow open folder symbol. I navigate to symbols>cities>CA158 Ferraris Style and then select Vegetation. It loads correctly for me.
If that is what is crashing things, then I suggest a few things.
Hey Sue,
Neither option are working - they are both getting the same result. I am using Imperial.
No problem at all. I'll have to get upstairs to do it here in a bit. Working in the office right now.
Did you get it working anyway, Eric?
