Text Angle
Ricko Hasche
🖼️ 103 images Mapmaker
Hello all, is there any way to avoid de angle clicks when holding shift on text and make it smooth?
Thank you
If you mean using the "Rotate" command on text, you can just rotate the angle of the text freely without using Shift at all.
If you need the text to be at a specific angle (which the Shift key option allows, but only at 15° intervals), use one of the Edit Text functions (such as Numeric Edit, or Edit Properties), and just type in the angle you need the text to be at.
Another way is to hold down both the CTRL and SHIFT keys at the same time. The disadvantage of using them together like that is that its very easy to press only the CTRL key for a split second before you hit the SHIFT key, which makes it easy to accidentally scale the label instead of rotating it.
this is what i was looking for. Thanks
