Symbol rotation / mirroring changes with effects on
I am working with effects turned off and place some book case symbols on the map back to back. I set rotation and mirroring so that the lighting of the symbols are consistent to each other.
When I turn effects on some of the symbols do not maintain the rotation / mirror setting and there is nothing that I can do to get them to hold the settings that I want when the effects are on. I have attached screenshots to show what I mean.
The only effect that has been applied to the sheet that I placed the bookcases on is Wall Shadow, Direction. I have tried turing this effect off but still the same thing happens.
Any ideas what might be causing this?
Effects turned off
Effects turned off
If not, install it (Get it from your Registration Page), otherwise I would recommend contacting ProFantasy Tech Support, maybe they know what is going on.
It seems bitmap symbols do not accept one negative scale: if your mirror is vertical, as it seems above, xscale is turned to -1 and yscale stays at 1.
Are you sure the rotated ones are affected too ?
The bitmap symbols that only have rotation applied are unaffected.
EDIT: If I turn effects off then the symbols are drawn as desired.
As I am running with the latest patch CC3 3.24 so I will contact tech support.
