how to import default terrain?
Ricko Hasche
🖼️ 104 images Mapmaker
Is posible to import Default terrains from one style to another?
Example:
Im trying to importo some default terrain from Spectrum Overland on my mike Schley file opened.
Some images appear, some just a line, when i select this line (terrain default, desert dark in case) i just can do the area and appear me a line, instead of the Ground effect.
Thanks
Insert a map that contains the fills that you want.
Before placing the second map, press the escape key.
Go to bitmap fills under FS and the new one will be in there.
Or, go to tools and click on Import bitmaps.
tools / import bitmap / I select bitmap desire = program show me a window that i imported XX files imported to the current drawing and... i cant find them. where they go? :)
They should be on your list of bitmaps in the Fill Style (FS) button, top right
