Mini city with overland tutorial
Ricko
🖼️ 106 images Mapmaker
@Bidmaron its how i make citys using Overland Map.
1 - displace hills, moutains etc. select in your mind the area where you want to displace the city
2 - start with 2 walls and 1 tower "hidding" wall conexion.
3 - places some constructions inside and one more wall - direction you want of course.
4 - Repeat the process how many times you want.
Put gates (note if you want more houses behind the gate, put them before, or work with sheets... or sent to back and send to front Comands on your right.
5 - add more houses to fullfil the town.
6 - start to close the city walls. note the bad conexion between walls on south corner.
here you have 2 options:
Hard hay - calculate well the distances.
Easy way (this time) - hide then with some outside detail.
7 - full with trees and hide the bad wall conexion with some outside trees and its done XD
8 - now create a new sheet (i name symbols trees GRASS) and work on this sheet now
9 - Select Scrub vegetation and full the areas you want to give grass
10 - refresh you draw and you will see the grass going down from the hills.
Use terrain grass land and make the roads (i do it on step 8, forget to comment sorry)
11 - Activate your sheet effects and Voila :D
Cheers
Another great tutorial :)
Thanks very much, Ricko!
thank you!
I am still wading through the annuals, but unless this is in one of the ones I haven't gotten to yet, this sounds like an annual to me!
Thanks so much @Ricko Hasche !
Im using Mr. Mike Schley Overland style, shure you have it if are instaled CC3+ Version.
The walls, tower and gate are present in some of the montlhy free content.
Cheers
