Export to PNG rendering passes
Can anyone tell me how to set the Save As export to PNG to get more rendering passes? It was doing 3 passes the other day, but now only seems to want to do 2, which leaves about half of the 2000 x 2000 poorly rendered, while the other half looks great....
Thanks,
Darby
    There is no way to specify the rendering passes manually. CC3 uses the number needed, based on map size and effects.
    The number of rendering passes shouldn't really effect quality though. What part of the map looks poor. Is it something lik "the left half of the map", or is there certain fill styles that looks bad. If so, try to set the bitmap quality manually to very high before exporting, and see if that makes a difference (Found in the Display Speed Settings dialog image)
