How do I add Coastline when Changing Styles
So I have copied one map over to another style. I am in the process of converting it. In the original, there was no coastline. However, this new style requires a coastline. So how do I go about adding it? Will I need to use the trace command and draw it all?
When you use "Change like draw tool" on the imported landmass, it will add the coastline automatically as long as the tool in the new style uses one.
Thanks, I was just using the change properties and then selecting what was appropriate.
You can copy all your land masses, and use Change Properties to change that to coastline.
