Export from FT3(+) to CC3 - usage of bitmap fills for contours instead of solid colours?
With the (new) export possibilities from FT3 to CC3 by using templates I wonder if it possible to set the fill styles of contour lines and where to do it?
E.g. with the Herwin Wielink export you get bitmap fills for the sea and the land. Would it even be possible to create bitmap fills for mountain regions within the export?
Thank you,
André
Generates entities in a few categories like "Land Contours", "Sea Contours", "Rivers", "Rectangular Grid" and so on. It has no notion of more fine-grained ideas like specific styles for specific kinds of contours (e.g. use fill "Mountain" for climate type "Mountain"). It's a good idea, but there isn't a way to make FT directly output such things.
A follow-on idea would be to have FT generate contours from Image Overlays to allow direct painting of fill styles, but that's a whole different kind of thing.
I've had some recent success doing just this, but it's not automatic. I did it by creating masks:
This method is far from perfect. If anyone has tips on how to improve it, I'm all ears. I hope this helps, though!
