Multiple Floors/Layers
I'm sure this has been asked ad nauseum, but is there a way to copy features from one floor to others instead of just redrawing it on a different floor?
Thanks in advance
Thanks in advance
Yes, you can copy from one sheet to another using Copy to sheet in the right click menu for the Sheets and Effects button.
If you are talking about separate map files, you can copy and paste using CTRL+C and CTRL+V. Watch the command line for prompts to take the next action each time. CC3 will ask for a copy origin and a paste origin. If you want things to be in exactly the same place use the origin coordinates - just type 0,0 and hit enter each time.
TY
I will try and hopefully not screw it up.
And a third method.
I make the floor outline, building, dungeon, etc. Put in stairs.
Save it as floor01
Save as floor02
etc.
That way they all line up.
Thank You all,
Need to practice on the command line
