Strip Map problems (Annual 29)
Anyone had trouble using strip maps?
I notice that if I click on the Erase button, it immediately erases my map.
If I click on the Move, Scale, Rotate button, it selects my whole map to be moved/scaled/rotated.
If I click on the Bring to Front button, it applies this to the whole map.
And so forth.
Can anybody recommend a fix/workaround?
And so forth.
THANKS!!!
The select method sometimes gets messed up if a macro is aborted midway, since these often change the selection method (And change it back only at the very end of the macro). SELBYD restores the selection method to the default one.
I wish CD3 could be used to place houses alongside the streets. That would save time drawing all those buildings. I'm sure there's a way to do that, but I haven't figured it out.
