Printing and exports
Hi
I have created a few maps now and I am pleased enough with them to start putting them into other documents, particularly Inkscape and Adobe Indesign. The problem I amhaving is the export of the image seems to only export at 72dpi if I use PNGs (which is by far the most useful export). This is just not high enough resolution for printing. Is there a way of increasing this resolution, or does BMP or JPG allow for higher?
Thanks
Thanks
Post if either you cannot find the options, or they cause you problems.
Steve
Ralf - As I understand what you are saying is
Save As -> PNG -> options and choose a large bitmap size then edit in Gimp/similar and change resolution there?
Will give that a go - Thanks
