Installing the Harn Mapping Tools to a New Install of CC3+
I have just installed CC3+ on my new machine. When I tried to add the Harn Mapping Tools from Roy Denton's website, the instructions say to copy the files into the CC3Plus folders. However, the new install does not have any folders!
Can anyone help?
Sounds like you are looking in the installation directory, and not the data directory. You'll find the data directory in
c:\ProgramData\ProFantasy\CC3Plus(unless you changed it during installation). Don't confuse theProgramDatafolder with theProgram Filesfolder.An easy way to open up this folder from inside CC3+ itself is to type
OPENDOCon the command line (followed by enter), and when it prompts for document to open, just type@(followed by enter).Thank you for the suggestion.
Actually solved the issue with a different method and discovered that the files are now kept in a different place than previously. Not sure if it is a Windows 11 or CC3+ ver 3.97 thing.
