Installing City Designer when CC3+ is not in C:
Hello
I want to install the Profantasy products in my D: drive (Window 10) rather than on the C: drive. I'm given that option during installation, but it appears that City Designer cannot find CC3+ when I try to install it. Is this a limitation of the installers? Or is there a workaround I can use?
thanks!
It shouldn't be an issue. Are you sure you are using the City Designer for CC3+ installer, and not the one for CC3?
Hm, yes, I'm using the installer "CD3SetupForCC3Plus". I also saw this issue when trying to install the 3.97 update. I just now looked, and it appears that though I specified the D: drive when installing CC3+, it installed in both C: and D:. Kinda looks like I need to remove & reinstall it...
Edit: looks like I needed to first run CC3+. Der. Sorry to bother you! I got into this fix because I'm installing in a new PC and am doing all the product installations.
Edit2: (face is red) the data directory is on D:, so I'll just walk away now... sigh
