Fill Style Import - How to?
Fellow Mapmakers,
I have a question concerning Fill Style Imports. At the moment I mostly use the "Annual 148 Moody Mansions" Floorplans for my projects. I came to the point where I thought that some more Fill Styles for the floor itself might be a good idea. For example the Annual gives me a red and a green carpet fill but I just looked online and found some more carpets with different colours. These seem to be all png files but at the moment I do not have a clue whether- and if so- how I could import them into my Fill Styles.
Maybe you have an idea how to do this? Maybe you could point me in the right direction?
Thanks in advance!
Make a folder called User in the Bitmaps folder here:
C:\ProgramData\Profantasy\CC3Plus\Bitmaps
Then put your png fill style in that folder and import them using Import bitmap fill styles in the Tools menu. You should then be able to pick them in the Fill Style Properties dialog and use them as polygon fills.
Thank you, Sue!
I really appreciate your help!
You're welcome :)
If you need more detail about it Remy wrote a FAQ on it here:
https://forum.profantasy.com/discussion/comment/99096/#Comment_99096
Thanks again!
I just played around with some fills like concrete, bamboo, etc. Seems to work exactly as I wanted it to.
This keeps getting better and better... :-)
