Not angular Shoreline?
Telnango
Traveler
Hello everyone I´m looking for a short advice - so far i did a few dungeons with cc3+ but now I´m starting with overland mapping (Mike Schley). And here my question comes. As u see on the picture I create a coastline with [Default Landmass] Tool (path/polygone). Somehow the Coastline edges look very sharp - is there a way in the settings to get more smoothy lines, so that the coastline does not look so angular? I already found the [Advanced settings] but couldn´t find what I´m looking for. Maybe some of you has a hint for a newcomer ;-)
Thnx a lot
Hi Telnango :)
If you right click the Fractalize tool on the left
you will see "Straight to smooth" at the bottom of that list. You can use this to turn those lines smooth.
However, I recommend doing this at the end of your mapping work, since CC3 makes a better job of tracing a straight line entity than it does a smooth line entity.
I knew it was simple ;-) you just have to have the knowledge ;-)
Thnx - I try it
