Lines on Gaia map view output from FT3+
I'm loving the new FT3+ but found what might be a bug.
When I save an elevation map as a PNG it saves fine. But when I try to save a Gaia map I get these streaky lines. This example is 9000 width so I thought it might be the size, but I've saved smaller images and it's the same.
Any thoughts? I'm using the latest FT3+ in Windows 10. I had no problems with this on the earlier version.
Certainly looks like a bug. I've notified the developer.
It's a recurring bug relating to threading. It's been in the category of Heisenbug for years now (try to debug it and it disappears) and is related to (but not precisely the same as) the bug described at How much does the Random Seed Affect FT3+? — ProFantasy Community Forum. Oftentimes, it's enough to resize the window slightly, which will cause a redraw. If you're exporting and can change the size slightly (e.g. 10%ish smaller from 9000 to 8991), that may also be enough to trigger a better state.
Would it be possible to get a copy of the problem file so that I can examine it more closely?
