Grouping and Ungrouping Items on Maps?
Is there a way to group or ungroup drawn items together? For example, a terrian is drawn using a hatch file. That has many images in there that are all grouped. If you try to delete one part of it, you delete it all.
I thought there was a way to ungroup all of that so you could edit parts individually and then regroup it back together if you wanted to. But then again, maybe that was something I dreamed.
To unlock groups, just click the Locked button in the lower right. This allow you to edit entities as if they were not grouped, and then you can simply hit the Unlocked button to lock them back up again.
You can also use the commands under Tools -> Groups to group/ungroup entities.
