Strange problem
Hello!
When I click the floorplans button and then click the target house nothing happens.
When I click the screen it only gives the message:
Command [FLOORPLAN]
and when I click again it gives the message:
Select a Layer: *Right click for the layer dialog or *Type a layer name
Hi Nikode! That looks as if your selection method by be set to "Select by Layer" perhaps by an aborted macro. Please go to Tools > Options in the menu and under "Select Method" set it to "Select by Dialog or Popup". Does it work properly again, afterwards?
Thanks! Great it works.
