Looks very nice, but since you have gone for a more "expanded" settlement view, instead of a single symbol, maybe that dashed line for the road isn't the best, as it crashes a bit with the rest of the visual. Those dashed lines work best when you keep everything on an "abstract" level (Such as using a single symbol to represent a town).
but after i realize that Ushuaia was almost impossible to reach by land until around 1950... so was a perfect place for Argentina make a big prision there, cause escape was almost imposible. They have some historys from people who jailbreak and after they realize they was alone in a very cold place... they bagged to return to prision to survive.
based in this, i make the option to select the small road with dashed line, as indicator of a very very smal road....
I really like the way you've done the town - great use of the structure symbols :)
Initially Ithought in make solid road on map...
But i understand your tip. Thank you.
A solid line with gaps here and there ? Not spaced the same. I have seen that on actual maps.
