Sheet Effects make map yellow
I'm using the Annual OSR map. I have these effects:
- Wall shadows on my walls.
- Inner Glow for water.
- Transparency on Grid.
When I activate these effects, my black and white map turns yellow like above. Any ideas?
The default Annual OSR template has a whole drawing RGB Matrix effect to give it a more aged feel. Just switch off this one if you don't want the yellowing.
Thanks Monsen!...where do I find the switch?
Pick any sheet you want and then hit the 'Whole Drawing' radio button on the top right. This map doesn't have any sheet effects that affect the whole drawing, but this is where you will find at least one effect on yours.
Thank you so much!!! That did the trick!
