Cartographer´s Collection 2 - installing problems
Trencher7
Traveler
Hello there,
I just got the humble bundle and although all other installations went fine I keep having problems with CC2.
During the process an error message keeps popping up.
I checked the folder and the file is defenitely there.
Is there someone out there who could help me with that matter?
Thanks in advance!
Give me a moment, I'm currently uploading an alternative setup to another location so you can double-check whether it was the download causing this. Will post here with the link when it is ready.
Thank you so much for the fast reply!
Here is the link: https://s3.amazonaws.com/aws.profantasy.com/alternate/HCC2_SetupAlt.zip
Please try whether this avoids the error message. I also recommend to manually unzip the file before running the included setup.exe.
Perfect!
That settled it!
Thanks again for your fast help!
Hi, I am getting the same error with this alt setup. It seems to be searching the C drive for data that's on my E drive where I unzipped the file.
Thanks.
@Rob Webber I recommend you contact technical support for a quicker response.
