Wizard template: Everythings is great except no tools
Lillhans
                🖼️ 7 images Surveyor
            So, I am getting this when trying to access drawing tools in Wizard-created maps as well as the map file in which I created the template file. Any suggestions as to where I might have goofed up?
I did change the associated name of both the template and .dto files so if that's the culprit I at least know what to avoid on my next bombing run...
Best Answer
Monsen
                 Administrator 🖼️ 82 images Cartographer
                    In , make sure to pick the correct draw tools (These are the names of the folder the tools reside in). Obviously, you should do this in the template to ensure new maps crated from it will work properly
Answers
In Drawing Properties
Thank you so much @Monsen! This feels like a perfect moment to procrastinate. Or create those multi-sheet symbols.
