Question about the auto house settings.
kevbeck43
🖼️ 13 images Surveyor
I was messing with the house settings for a map I am working and I tried to add chimneys to the houses using the symbols on top tool in the house settings. For some reason when I check the box, select the symbol catalogue and then the small chimney symbol in the Darklands Cities annual and hit ok when I go to lay down the houses the chimney's aren't there. I don't have CC3+ in front of me right now so I can clarify if needed when I get home but does anyone have any ideas?
Try going into the dialog and setting it again. For some reason, it seems to not stick the first time when you pick a new catalog for the frill symbols in the settings dialog. Going back in and just picking it from the dropdown again (and then saving the house style) seems to work for me.
Cool, I'll try that when I get home. It will let me save it with a unique name right?
Yea, you can save it under a new name so you don't mess with the existing one. Keep in mind that if you save it under a new name, remember to actually select the new one when you get back to the house dialog, it won't automatically jump to the new one you saved in the settings dialog.
