Yes, I have, especially as I have all the smaller divisions that were made available eons ago. However, I only started on it then left it, as I was only very much apprentice (or even just novice) level at that point - not even the first issue of the first annual has come out. But the Pete Fenlon style (Annual 2, issue 1) may change that whenever I catch up with all the mapping projects i have.
the NW files are defeating me at the moment. I can only produce a low res version. Any higher and cc3plus crashes.
So this is unfortunately the best quality i can do at the moment.
note that the the shape of the NW doesn't match, the original continent map. I've redrawn it, to match the shape shown on later b/w maps in ICE products.
@Quenten - The scale bar on the Pete Fenlon map is 600 long (each larger red or white division is 100), I'm guessing miles, judging by this zoomable higher-res version. I don't have the actual map or RPG materials though to definitely confirm.
This is a timely thread for me. I have been looking at Middle Earth maps recently and thinking of making one. All of the reference maps have only been for the west section. This is the first time I have seen the entire continent. Makes me wonder if I should go big or stick with the west only.
hi
something like this?
There is a version for the northwest, but i'm having an issue with the file for some reason.
if i sort it, i'll post it
update i've found the issue with the map and added it to the post.
thank you
Yay whit2468!
excellent
*rubs hands*
Cal
I have a lot of small regional png's with a little detail on them. Here is one just made into Pete Fenlon style map (Annual issue 13).
First the little map:
Now my Fenlon version - admittedly a rough and ready version, with the blurb that came with the regional map.
Here is the Fenlon map with the location of the smaller map.
I don't have a scale - can anyone illuminate me? @whit2468
heres the full map, finally finished after years of languishing on my hard drive.
Wyvern is right about the scale of the original map. if you have the grided version, the grids are sized 200x200 miles.
Added some trade routes to the map.
some more maps based of the arda map
Are you using "Majour" here because it's an obsolete, thus archaic, form of "major", or is it actually a typo?
