How to attach water to edge of map
Hello, I'm following along on this live mapping session: https://youtu.be/8CQU7P9U13M and I can't figure out how to make the river hug the edge of the map. When I try tracing or just drawing it along the edge, it creates a curve.
Here's what it should look like:
I'm using the water, curved drawing tool like he is using in the tutorial video.
Thanks for your help!
    Turn off snap (lower right corner) when working, this allows you to place nodes right outside the map border, and let the functionality that restricts it to the map border kick in.
    With snap on, you are basically just placing nodes at the edge, but not over it, so it treats it as a regular corner. Note that you can achieve this with snap on too, but you need to move your cursor much farther out from the edge of the map to hit the snap points on the outside and not those at the border itself.
    Balamor
  • Excellent! Thank you so much! 😀
