New Land Fill Style
Hello,
I am attempting to create a map that is the "underside" of an existing land mass (setting physics aside of course).
The current land mass FS is Land_MS. I am hoping to find something similar, but with purple hues to it (instead of green). Two questions:
- Can this be done in the software?
- If not, thoughts on where one might be available for use?
Thanks!
Assuming that you're doing the underside map in a different file, the simplest way would likely be to draw your landmass, then add an "Adjust Hue/Saturation" effect to the LAND sheet with a Hue value of 90. If you want to have the two images on the same drawing, you'll need to put the underside parts on the LAND sheet on a different sheet before applying the Hue adjustment.
It's also possible to make a new fill bitmap in your favorite image editor and use that to fill the underside elements, but the Hue adjustment described above is simpler and doesn't require an external file.
Perfect - Just what I was looking for.
Thanks!
