Problem with FT3 Export to Cos3
landorl68
Newcomer
I have CC3+ 3.94 and FT3 3.0.21
When I try to export word to Cosmographer, when I navigate to the \templates\cosmographer\
folder, there are no templates showing up to export to.
If I manually navigate there, I can see them in Windows Explorer.
Is there something that I need to do to get this to work?
When you export a map from FT3 it uses it's own internal template according to the export settings. If you have asked for a Cosmographer export it will produce an FCW file that is suitable for Cosmographer, though you may have to copy the contents of that file and re-paste them in a new file created in the style you wish to use.
Thanks. I thought that it was trying to load a template. that helps a lot.
You're welcome :)
I use the Cosmographer export for my Traveller site. I use the exported fcw file to add major locations, names seas, oceans, etc. I haven't done that much on the maps I have posted to my Traveller site.
https:///travellergame.drivein-jim.net/
I tried to make it a clickable link, but even though my site has a certificate, it wont load under FF.
