Non-Regular Hexagonal Grid
Is it possible to set a grid that doesn't use regular hexagons. I would like/need the hexagons to be slightly stretched vertically. The Width and Height cells of the "Edit Hex Grid System" appear to be permanently set be proportionally linked.
Is there perhaps a command-line method to set it?
No. CC3+ doesn't support such grids.
For the visual grid, I guess you can just draw it as a normal grid, then simply scale it a bit in either X or Y directions, but you won't get a snap grid that matches.
Yeah, that was me assumption but figured worth asking before just giving up :)
Thanks
