deck isn't showing shadow with hull
HelenAA
🖼️ 19 images Mapmaker
I can't get the shadow effect where the deck's outline meets the hull. I've tried any number of things, including looking at the predefined files, but the deck stays obstinately on top of the hull with no shadow where the edge of the deck touches the hull.
Here's what I've got.
The reason for this is that the hull is a massive polygon below the deck polygon, so there isn't really and edge here that can cast shadow as far as the hull is concerned. And the deck itself is set up to cast a shadow, but shadows extends outwards from the caster, not into it, you can see you have a shadow from the deck in the lower right of the map.
What I would have done here is to use a black glow (set to inside) on the Deck sheet, and disabled the wall shadow on it.
thanks
