Help locating some symbols.
I'm in the process of converting older drawings into bitmap and I stumbled on three vector symbols which I can't even find in the older vector catalogs, and I've scoured every one of them. The first two images are what I am looking for.
I have no idea where to find those, there used to be much more user-created symbols floating around in the good old days because of the ease of making them.
But if you only want those specific symbols, and you have the map, then you have the symbols. Symbols are embedded in the map, you can even load up that map in the symbol catalog window and use the symbols in it in another map. If you wanted to know because you wanted to check out what else might be in those catalogs.
Checking the names of the symbols may possibly give you a clue though.
Thank you! I didn't look in the Overland catalog.
