Missing Drawing Tools?
Hello,
I was toying around trying to figure out which city style I wanted to use and notice what I think are some missing or incorrect drawing tools.
As you can see, a number of the drawing tools don't seem right (although I would not know since I don't know what they are supposed to look like) and two of them seem missing altogether. There are a few more missing ones and then one that is a strong color purple.
I thought maybe the install was bad so I reinstalled the annual the Jon Roberts city style cam with.
Any idea what is going on?
Did you start the map as a John Roberts map, or as another style?
I notice you are missing all the Cliff tools (but seem to have the others). These are not part of the original style, but added by the City Cliffs annual issue from the 2020 annual. This would indicate that your template is still an old version without these fills defined.
Try to re-download the latest version of the 2020 annual installer, and re-install it. (If you don't own the 2020 annual, you are not supposed to have these cliff tools, if so, the tools themselves may have been added by an error)
I started it as a John Roberts map.
I reinstalled the 2020 Annual. this is what I see now:
I am totally missing (by which I mean the tool image appears to be missing like the lower left and right of the image) the following drawing tools:
Cliff, Water Turbulence
Terrain Contour Higher
Map, Cartouche Line
Map, Cartouche Line (there are two of them)
Terrain, Contour Higher
Water, Waves
In addition, some of the drawing tools seem to not be of the right texture or color, but I am not sure because I don't know what they are supposed to look like.
Thanks so much for the quick replies, LoopySue and Monsen.
Map, Cartouche Line
Water, Waves
Alle of these draw white/transparent areas, so they are just a bit invisible against the white background of the drawing tool list.
Good to know. Thanks!
