Map overlay?
I found a town map in an old issue of Dungeon magazine that I would like to recreate in CD. Is it possible to scan that in as an image file and import into CD, give it its own layer, draw over it with the CD3 software, using the underlying map as a guide, and then hide the layer?
  • MonsenMonsen 🖼️ 44 images Cartographer Administrator
    Yes.
    Just put the image on it's own Sheet and Layer so you have easy control over the order and can change the order by moving the sheet.
    Umbratikus
  • UmbratikusUmbratikus Newcomer
    How do you import the image? Sorry if that is a basic question. I am still a newbie at this.
    Draw menu -> Insert file. Create your temporary sheet and layer first, and make those active so the image goes straight to them.
    Umbratikus
    Awesome. Thanks Monsen!
