movesht once a symbol is placed ? other than manually
I was going over an Isometric dungeon map. I couldn't get shadows to work on the walls. So I did a List. The walls are on the Symbols sheet, not the Symbols Walls sheet.
I can move them using the movesht command; however, it is very difficult due to the floors also getting selected.
On the below jpg I have moved some of the walls. As you can see, it is difficult. I did hide all but wall sheet, and some of these walls are on the walls sheet. But not all of them. Probably no more than 30 to 35 percent.
Can I use something else, like the Symbol Manager, to help move these walls to the Symbols walls sheet ?
Thanks.
Check if they perhaps share some common property that the floors doesn't have. Such as color, line style or layer. If you find anything, you can then use that as the selection criteria.
Okay. I'll check tomorrow. On my cell.
