Question about Using Annual Symbols
I'm making a city map with one of the annual styles. When I click on a different symbol set or different add-on, such as DD3, the only way I've found to return to the original annual symbols is to click on the folder under options and load the symbols again. Is there a simpler way?
Thanks
If you click the add-on buttons, that will often change the symbol filters. The fastest way to go back to the default settings is to re-open the map, since this loads the settings again. And the quickest way to do this is just to first hit save, then pick the top option from the recent map files at the bottom of the file menu (the current map should be the top one)
Thank you, Remy. This is good to know.
