Wall connection - again ;-)
Another Morning, another Question
So, I have two walls, one Inner Wall one Outside Wall I want to connect.
Both walls are on the same Layer and the the same sheet
I read: "...use the LINE TO PATH or COMBINE PATHS tool (right mouse on the FRACTALIZE button"
that is what happend:
I don´t understand why it has to be a polyline if I want to combine Paths.
I sure I got something wrong - but its like a daily learning be doing.
You won't be able to combine those outer and inner walls because you can't create joins.
The tidiest thing to do is use the Send to Back button
and send that little piece of inner wall behind the outer wall.
ha who could imagine, that there is a missing tool in this great software ;-) still I´m a big Fan of CC3+ ;-)
