Unable to draw lines outside of an invisible bounding box
I've had this problem a couple times now and I can't figure out what's going on.
Let's say I have a map that's 1000 x 800. No grid, no snap, nothing of that sort turned on or used in any way.
I'm mapping borders, roads, etc. as usual, and then suddenly I'm no longer to draw lines outside of an invisible "box" that is not the same size as my map. It's smaller, different dimensions, and offset. Note that this isn't a situation where the lines don't appear because they're underneath something. I mean I literally cannot start a line or cross a line over this invisible barrier - the line tool stops when it hits the hard wall, as if I were snapping to something.
It seems to be related to the drawing size itself. I've got some drawings that have this bounding box now at exactly the boundaries of the map. But the one I'm working on right now, the bounding box is much smaller than the map. And it wasn't doing this before.
It appears also to be related somehow to three of the text objects. When I delete them, I can't draw lines ANYWHERE. And if I resize the drawing area, only those three text objects move and scale.
CC3+ file attached showing the bounding box, which I made by using the river tool, which snapped to the boundary and could not draw outside of it.
Any ideas?
Best Answer
Loopysue ProFantasy 🖼️ 41 images Cartographer
Hide all the layers except the MAP BORDER layer. I do mean layers, not sheets.
If you have anything on that layer that isn't the map-sized bright green box, then it needs to be moved to another layer.
Answers
That solved it!
So if I'm understanding you right, the MAP BORDER layer creates the bounding box of the whole map, based on whatever is in that layer?
Yes, that's right. So if anything else ends up on that layer it will also serve as a barrier to drawing tools that are limited to operate within the map border.
