FT3 to CC3 Export Settings
I have successfully imported contour data from FT3 to CC3 using the Basic 100 Export Setting. Naturally I want to be able to customize the export that I am looking for, however I get an error message when trying to create my own setting. So I tried to edit an existing setting, and it still won't allow me to save it. So I used the Basic 100 Export, edited it to the parameters I want and tried to export it. No error...HOWEVER upon closer inspection the contouring was completely unchanged when compared to the results of the unedited Basic 100. I am vexed, please help me to understand how to create an export setting, and most importantly get the export that I actually want/need. Thanks!
FT3 saves these settings in its program directory, so the only way to change them if you have installed FT3 in the default directory is to run it with administrative privileges. You can do this by right clicking the program icon and choosing run as administrator. This only have to be done when changing these settings.
That did the trick! Thank you so much Monsen!
