"The Most Accurate Flat Map of Earth"/"Astrophysicists Design World Map That Looks Like a Vinyl LP"
are some of the headlines in the last few days and a projection of earth looking like this
is presented in many articles all over the internet.
My first question was - can we reproduce this or a similar projection in FT3?
And luckily the answer is: Yes, we can!
Here is my result of projecting the ETOPO2 data in a similar projection.
It seems to be partly the old fashion "Azimuthal Equidistant" projection - but limited to the northern (or southern) part only.
You can add the following lines in your projections.txt
file in your FT3 installation folder to get this projection:
Projection 90, "AE Northern and Southern Hemispheres"
Scale 1.0
Description "Azimuthal Equidistant Northern and Southern Hemispheres"
Segment "Azimuthal Equidistant", 90, 0, 0, 0, 1, 0, 0
scale 1, 1
Offset -0.5, 0.0
Effective -180, 90, 180, 0
Rotate 70
EndSegment
Segment "Azimuthal Equidistant", -90, 0, 0, 0, 1, 0, 0
scale 1, 1
Offset 0.5, 0.0
Effective -180, 0, 180, -90
Rotate 110
EndSegment
EndProjection
Greetings,
André
I tested the projection on Nibirum and I think it looks quite interesting...
Neat stuff.
Just tried it on my Myirandios world, and it worked really well. Thanks, WeathermanSweden.
