Cannot uninstall, repair, or install CC3+
Hi everyone, first time posting but I'm having an issue that I haven't seen fixed anywhere.
My drive address changed from E: to D: so all of my shortcuts etc. don't work. That was fine as I was doing clearing up and uninstalling to then do a fresh install. I tried to uninstall all the smaller parts and addons etc. but to no avail as the drive doesn't work. I went int HKEY etc. to manually remove them adn even installed multiple uninstaller programs to brute force it out. None of these have f ixed the problem, so now I have a bunch of paths to a drive that doesn't exists, with no data or anything of the programs on my computer AND I can't do a fresh install because the wizard wants to repair or remove the files instead of doing a fresh install.
Does anyone have any advice or ways to solve this, or do I need an admin with some behind the scenes skills or something to help with this?
Change the drive address back to what it used to be.
Try the SUBST command to map the (non-existent) E: drive back to your D: drive, e.g,
SUBST E: D:\
