I've made a large map
I have map a rather large map but want to save a portion of it as a battlemap and the rest as an area map so I basically want to cut one map into two and save them separately. How do you do this.
Aramis
Aramis
I think this might be what you're looking for. ?
No this is about making details with two different maps. Thanks for trying
Save As and select rectangular png or bmp or jpg.
Upper corner to opposite lower corner.
On my cell, but that should get you started.
@JimP has it. Toggle Snap to ensure you get the part you actually want; you may want to even set up a border around the area to this end.
If I am going to import the map part into another template to use as a giuide. I make a hollow square on the area. Use Info menu -> distance. Then add the distance in text for both horizontal and vertical measurements.
Thank you all for your help
