Run a report of symbol locations
Will Mason
🖼️ 97 images Traveler
I have a question. How does one run a report of the symbols used in a CC3+ map and their locations on the drive? I'm sure I've seen someone do this but I haven't found it in the forums yet. Thanks in advance.
I did find this article, but not there yet.
You can run the LISTIMAGENAMESDWG command to do this. It will list all the images in a drawing, and tell you if it is a fill style image (bmpsty) or a symbol/inserted image (pictr2)
You can also use my custom command that list images sorted by addon. Note that the accompanying data file is a bit out of date, so a lot of files will be identified as unknown add-on.
@Monsen , those are awesome tools. Thank you so much!
